3 members (Robert Crandall, 1955 1 Series, 1 invisible), 328 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Can you tell how old a weld is?
Sure! Is it hot or cold?
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
grin
Is it shiny or rusty?
You mean like carbon dating it???
dg
Denny G
Sandwich, IL
Yes, like carbon dating it.
Can you carbon date a weld?
If the weld was created at the factory or at a later date.
Example:
Lets say, the factory worker stamped out a piece of metal.
During the stamping process, the stamped out a piece of metal split, tore, ripped or cracked a little.
Rather than trashing the entire piece of metal.
The factory worker repaired the flaw with a weld.
Do you think they would try to repair the piece of metal or trash it?
U
U Offline
Fact- yes in a lab, a section of the weld could be dated depending on what was used to weld it. 14-C has a specific half-life, or decay rate that would be used in the calculation.
Opinion- I think the factory worker repaired something (in your story), but I do not know how stringent quality control was (in your storyline)
Fact- Times were lean and resources were valuable and scarce (assuming you mean this factory worker was in an auto factory WWII-Korean Era). Things were repaired.
Edit- if this "can you carbon date a weld" is informational, fine, but I wanted to let you know that mass spectrometry labs are phenomenally expensive. Just in case your next question went there.
Brad
Wrench Fetcher, PhD
U
U Offline
After asking some actual experts- it could be done, but 12C or 14C dating would not be able to determine the answer to your question.
The dating could come back that the weld was older than the metal it was on-- by several years...
Thanks for the mental work, though!
Brad
Wrench Fetcher, PhD
Brad
Especially a panel, that is covered and normally not seen.
And structurally unimportant.
Brad
1953,1954 Era
Thanks for taking the time.
