| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 5 'Bolter | | 'Bolter Joined: May 2015 Posts: 5 | I'm thinking I should rebuild my starter so it will more easily crank and start the 216 engine. Any suggestions for where to find parts that I might need? Classic parts just seems to have rebuilt starters. I prefer to rebuild my original starter. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | If you have an Auto Electric shop close by, they can rebuild your starter a lot cheaper than buying one. Yes, they can get parts for our old starters (generators as well). Type Auto Electric and your zip code into Google and see what pops up. Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ken Warner at Classic Generator. He's been a big help over the years to me and the guys here on the Stovebolt: http://www.classicgenerator.com/ dg
Denny G Sandwich, IL
| | | | | Joined: May 2015 Posts: 5 'Bolter | | 'Bolter Joined: May 2015 Posts: 5 | Great. Thanks. BTW on another note I read someone's post about their '49 3/4 ton with a 6 volt positive ground system. I have 6 volt negative ground system. Were both produced, or were some changed along the way? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | With Denny on this one!! Ken Warner is a GREAT help!! Rebuilt my starter and converted it to 12 volts. Ken was extremely helpful with advice and the proper parts needed!!
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Great. Thanks. BTW on another note I read someone's post about their '49 3/4 ton with a 6 volt positive ground system. I have 6 volt negative ground system. Were both produced, or were some changed along the way? GMCs were positive ground. | | | | | Joined: May 2015 Posts: 5 'Bolter | | 'Bolter Joined: May 2015 Posts: 5 | Nice to know, but seems odd. Thanks. | | |
