1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1144159 01/10/2016 10:33 PM
I pulled the head off of a gmc 248 the number on the head is 2184819 can anyone give me any info on this head?
That's the same head that I have on my 270, it is used with the flat top pistons, with the slight dish in the center.
there should also be a date code cast into the head also, that will tell you when it was cast.
They were used on 54-59 248 & 270.
Here is some info on GMC heads
http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/462107036/m/71520754563
oops, my bad..had the number wrong, its actually 2194819..Its correct for all 39-63 228 248 and 270s
