| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 29 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 29 | I pulled the head off of a gmc 248 the number on the head is 2184819 can anyone give me any info on this head? | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | That's the same head that I have on my 270, it is used with the flat top pistons, with the slight dish in the center. there should also be a date code cast into the head also, that will tell you when it was cast. They were used on 54-59 248 & 270. Here is some info on GMC heads http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/462107036/m/71520754563
| | | | | Joined: Apr 2013 Posts: 29 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 29 | oops, my bad..had the number wrong, its actually 2194819..Its correct for all 39-63 228 248 and 270s | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
