5 members (Gdads51, tclederman, 68ironhead, chemanic, Otto Skorzeny), 102 guests, and 2 robots.
Topics128,101
Posts1,056,339
Members48,441
Guys ive been trying to come up with a solution for my busted 2 speed rearend. Ive thought of replacing it with a dana 80 from a p30 van. I'm also thinking of just swapping the third member out two a single speed. I'd like to here your opinions. Also i'd like to verify that the single speed with fit right into my 2 speed rear housing and match my axles. I have found a single speed diff but it is going to cost me 600 including shipping. I'd hat to get it and find out that it doesnt fit or that I also have to swap axles
or anything else. The numbers on my rearend now are:
3711468
GL109
Can you confirm that these numbers are a 15000lb axle?
From my searching I have found that the 2 speed axle is called a gm t-150
and the single speed is called an h-150. This is for the 15000lb axle.
What year/series is your truck?
Can you confirm the "G" is really a G and not a C.
Also, what are the numbers on the single speed rear?
Mike B
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike yes it is C. I dont have the numbers on the single speed. I will see if I can get them tomorrow. My truck is a 59 gmc 350.
If you could use another 2 speed, I have one from a 1965 GMC 4000 grain that has low miles on it.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
If that is an offer for sale or for free please either use a PM or the appropriate section of the Swap Meet.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
bcgmc,
I can't find the 3711468 casting number in my Chevrolet books (didn't realize you had a GMC until just now)...maybe it's a GMC number?
I do find a GM 15,000 pound 2-speed rear with the code "CL" as being made from 1955-59, it's has 6.40/8.72 gears.
CL = Code
109 = date (October 1959).
Is it Vacuum or Electric Shift?
Why are you looking to swap to a single speed rear? The 15k GM/Chevrolet single speed rears had 6.17 or 7.20 ratio. I don't think you will see enough gain to make it worth the effort/money to swap from 6.40 to 6.17...(3.6% increase at 55 mph = +2 mph more).
Whats the ratio on the rear your looking to buy?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
