| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | Bolters,
I am restoring a 1955 Series 2 6400. Being that it is a 2-ton truck I am finding it difficult to locate certain parts. Right now I am in need of finding replacement bushings and pins for the front and rear leaf springs. Does anyone have suggestions on where to look?
Also, do you know the size and length of the center bolt that runs through the leaves? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Try calling EATON Detroit Spring, Inc.. They do not list your parts, but they most likely could match/make/find them. If you need specs for the springs/parts, ask here or look in the GM Specifications Manual available at the GM Heritage Center. | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | I found the pins for my 46 2-ton on amazon, yours may be the same, the copper bushings were not long enough but mine were in good shape so i didnt use them anyways.
ACDelco 45G17004 Professional Rear Leaf Spring Center Bolt Kit with Bushing
they were only $3 each
1946 Chevrolet 2-ton
| | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | and here is the pin i used for the rear of the front spring
ACDelco 45G17002 Professional Rear Leaf Spring Center Bolt Kit with Bushing
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | For the 48 I went to my local truck spring spring shop. Had a couple broken leaves replaced and the bushings and pins were off the shelf. | | |
