5 members (Peggy M, Hotrod Lincoln, Otto Skorzeny, Ponchogl, msmall), 45 guests, and 3 robots.
Topics128,057
Posts1,055,816
#1143067 01/05/2016 2:12 AM
New to the 6 volt truck world. Basic question can you jump a 6 volt with a second 6 volt battery, as you do with 12 volt systems? Wanted to be sure I didn't burn up something before asking.
H Online: Content
Yes, but it would require BIG jumper cables, like #00 or larger fine-strand welding cable. 6 volt systems are very sensitive to voltage drop from undersized cables.
A very short boost with 12 volts to a 6V system won't damage anything. I prefer to do that type of boost with two people, one to make the starting attempt, and another to quickly connect the 12V boost after the cranking attempt is in progress. Be careful not to make any sparks near either battery- - - -make the final connect/disconnect at the ground connection.
Now it's been a lonnngggg time, but seems to me in the back of my feeble mind you need to be careful jumping a positive ground system with a negative ground system. Or is that just a rumor? Can't say I've ever done that.
I just charged the battery up fully.
Another quality post.
Real Trucks Rattle
H Online: Content
Just be sure to observe the polarity of both batteries while boosting. A "ground to ground" connection between positive and negative ground vehicles results in instant fireworks!
Ex Hall Monitor
Ex Hall Monitor
And NOT the kind you enjoy watching. grin
62401
But isn't that how you make a field expedient welder?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
H Online: Content
When I was a battery assembler on the line at Hester Battery Co. in Nashville TN, I saw two 8D series batteries (120 lbs. each)roll together on a conveyor line. These batteries had the terminals that hung over the end of the battery case, and they shorted together. The Pos and Neg terminals met exactly right and welded themselves together. 24 volts with a couple of thousand amps pushing the current makes for some very impressive lightning!
Used to sell 8D batteries when working at the parts store. Always had to have help to lift them. Couldn't lift one by my lone some.
I have jumped my 6 volt neg ground 49 3600 with modern 12 volt cars by attaching jumpers directly to starter with positive cable and to anyplace on frame where you can get a good connection with neg cable without any problems the cables do get a little warm and you should disconnect them as soon as the engine fires
