| | | Forums66 Topics128,196 Posts1,057,385 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | is there any way to remove scratches in side window glass? is it possible to buff them out or something? | | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | if they are light scratches and not deep enough to feel when you drag a fingernail across it, you should be able to compound it out with an agressive cutting compound.
rebuild not replace
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Eastwood Company sells some stuff for light and deep scratches in glass. But, I've never used it before. http://www.eastwoodco.com/ | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I've used the Eastwood product. Works well on light scratches--used on wife's show car. Patience is a virtue when it comes to the scratch removal process. Be sure to mask everything off real well and mark the scratches with tape on the reverse side of the window so you can easily tell where they are as you work. | | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | the glass will be out of the truck when i do it just waiting to here more ideas cuz i dont know where to get this stuff in canada | | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | Just order it from Eastwood 1-800-345-1178. They ship to Canada. I've ordered from them and have had good service. The #1919 Glass Polishing kit is only $19.95 in their catalogue. | | |
