| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | So is it possible to utilize the mechanical fuel pump with a regulating device to feed my Carb.\
Just don't see any reason to install an electric pump
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What carb? What pump (year/engine)? | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 |
Julian Carter
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Come on fellows. Why can't this be done?
Julian Carter
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | To be honest Steve,we used to use these on twin carb set-ups on VW racing engines and frankly they didn't hold up well. I do agree Webers and most other carbs for that matter will benefit from a steady,pulse free fuel supply and to that end we used to use these,a Malpassi Filter King regulator. They were used on many Italian exotics such as Ferrari with their multi carbed engines,they can also be retro fitted or bought with a pressure gauge for fine tuning and as an added bonus they have the filter. I also feel they look much better in an old trucks engine bay. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | re: jockbolter50 : It even looks like it should be in place. 54 Pounds? Current exchange is about 1(pound) to 1.48(dollar). That comes to about 80.00 dollars US. A little spendy for me.
Steve H
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | It even looks like it should be in place. 54 Pounds? Current exchange is about 1(pound) to 1.48(dollar). That comes to about 80.00 dollars US. A little spendy for me. Fair comment but then quality doesn't usually come cheap.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Savannah,
Do not use the regulator pictured. Get the Holley low pressure regulator and a liquid filled 15 lb guage. Adjust 3+1/2 lb.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are TWO factors. Pressure AND volume. As said the Weber wants 3.5-4. The stock mechanical pump gives 5.5 PSI. Don't know volume. If the pressure does not blow the needle valve and the volume keeps the bowl filled, you don't need a reg. Maybe you tried it without already? I don't now if you are building a dragster or what. But the stock carb and stock pump will run a 6 just fine. When you need a regulator you either have injection or are trying to match mismatched parts. Regulators can cause problems with volume, have leaks, go bad and a good one is expensive. Then of course you have to have AN fittings and SS hose and..... The entire WWW, started by Al Gore, says a Weber 32/36 runs perfect with a Cater 4070 electric fuel pump. $65, high volume, 4psi. Or put the Rochester or a Carter on with stock pump. Either way is not a mix-match and no regs. I don't know your history but if you have an Offy intake, a hot cam, EFI and all that, then it's a different story.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | Ever thought of altering/ tailoring the stock pump? Be sure to test pressure and volume at same time. David | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I use the stock factory fuel pump to run my twin weber setup I got from clifford
