5 members (Wally / Montana, Tinker5, Bill Hanlon, lumbersawyer, sron48), 150 guests, and 3 robots.
Topics128,080
Posts1,055,956
Members48,430
#1141074 12/24/2015 11:03 PM
M Online: Content
a friend recently gave me a set of very nice stock rims off of his 1997 silverado 4x4 to put on my apache, 6 lug 5.5 center to center, but my only challenge is that they are a little wider than the originals so the rim hits the tie rod when I try to install it on the front, backs have no issues. can I use these to solve my clearance issues?
http://www.amazon.com/6x5-5-6x139-7...ords=wheel+spacers+6+lug+chevy+silverado
not trying to go for a hot rod look, just something to get it rolling.
thanks in advance
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
May look a little weird, i.e.; wider in the front than the back but should fit.
5 Online: Content
I just don't trust wheel spacers. JMO.
Brian
1955.2 3100 Truck
Depending, on the amount of clearance you need, I would look for a set of wheel spacers that fit over original lug studs between the drum and rim. Install new longer lug studs if needed to securely tighten lug nuts. Me and a buddy done this to his '59 Apache on S-10 frame. I have also run the spacers on some 4x4's without issue. You should be able to buy the spacer and new lug studs cheaper than the item you are looking into. (My '55 2nd series 3100 uses the adapter/spacer on the rear to convert 6 lug to 8 lug. Just how the rear was made to fit the NAPCO conversion with 8 lug front differential. Again, I have had no issues,using the spacer/adapter.)
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
M Online: Content
well, after doing some measuring I will need about an inch of clearance, is this possible using the method you have described? I'm all for a cheaper alternative grin
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Sorry, I don't think it will. (I stated "depending on the amount of clearance needed") Spacers are only 3/8 to 1/4 inch thick. You would have to stack quite a few to achieve the thickness you need. You are better off with the spacer/adapter you were originally looking at. I think that they would work o.k.. Personally, I would find a different set of rims with a different offset.(For the reason "Justhorsenround" mentioned.
Stranger
Frank in Iowa
"Mater's Cousin"
