5 members (rfs56trk, Gib70, Lightholder's Dad, Gray_Ghost, 1 invisible), 134 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
Hi-
I just adopted a decent '63 stepside pickup and the column shifter won't cooperate...it won't go into reverse. It feels overall tight and resistant rather than lose.
It goes in 1st and second.
Any tricks I should know before diving into this linkage???
Ron Albany, NY
U
U Offline
First, take a brush and some good & soapy water to the entire length of the shifting linkage & clean it up.
Brad
Edit - the linkages under the truck is where I'm talking about cleaning
Wrench Fetcher, PhD
Any grinding noise? Try stopping before attempting reverse... ?? just kidding!
Comedy isn't my strong point.
If the soap trick doesn't work (which it should!), I'd consider attempting the shift under hood, with and without the linkage hooked up to column shifter. This would be attempt to isolate the binding culprit. The more worn out the linkage, the more unforgiving of sloppy shifts to the point where it may simply refuse the desired shift entirely.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Ron,
For what it is worth I just picked up a 63' and one of my first projects is squaring away the TOTT. I have some photos from a guy named Jay of his tear down I can share. I have some pics of my basic adjustment attempt I can share but not ready for Flickr site yet. The three links below from another forum site and on a youtube video on a later model.
http://67-72chevytrucks.com/vboard/showthread.php?t=215307
http://67-72chevytrucks.com/vboard/showthread.php?t=256851
http://67-72chevytrucks.com/vboard/showthread.php?t=452809
Not sure if you resolved but one of the closest threads to date. Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Thanks. Mine doesn't have that two bolt piece. I saw a video where a guy rotated by whacking that thing. I'm not sure how I'll rotate it - I'll try something else.
