| | | Forums66 Topics128,151 Posts1,057,001 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Before I started tearing into my 49 1/2 ton, I noticed that there was a hairline crack in the paint on both sides at the base of the windshield pillars (about 1" long from the door jam out). I know this is stress related where the cab parts were welded and then soldered. With the paint off, the cracks are no longer visible but I know the weakness is still there. Will opening the area up into a small "V" and refinishing with a quality filler be good enough? I'm thinking the filler would be more flexible than the solder was. Thanks | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The problem with solder is that once it cracks the crack will propagate. I would think that you would want to re-melt the solder to get rid of the cracks. Solder is actually fairly ductile and shouldn't crack as long as it was heated adequately when it was installed.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are talking about the solder joint area where the lower cowl joins in, you pretty much need to remove the solder with a torch. It comes off pretty easily. I would be wondering why it cracked. It means that the lapp joint underneath has been flexed. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The stress cracks in the trucks I have seen are not in the solder joint area, they are at the base of the windshield pillar right at the location of the upper crease in the belly band. | | |
