6 members (Otto Skorzeny, KEVINSKI, HandyAndy, Hugh63c10, klhansen, 37 GC), 144 guests, and 1 robot.
Topics128,114
Posts1,056,607
Members48,450
Okay, just about got my in tank fuel injection fuel pump done. Only took forever! I was mounting the tank on the frame when I had a look at the front bracket / strap. The rear strap touches the frame but the front one doesn't except at the top and bottom edges of the frame. Where the single bolt holds it in place, the bolt that goes throught the rear running board bracket, there is a gap of about 1/4" between the bracket and the inner frame. Is this correct? Am I missing a spacer there? Should that bracket be making full contact with the frame like the rear bracket??
It looks like the 1954 Suburban fuel tank mounts differently from earlier years. Maybe someone else has a picture?
I'm running into the same problem on my '48 truck, when I went to install the front mount today I have almost a 1" gap to the frame. The rear mount fits perfect. At first I tought the bolts holding the rear running board bracket were the culprit. Haven't been able to find any good pictures of the mount installed. Anyone have a front frame mount they can take a pic of? Thanks!
Larry
1948 Chevy 1/2 ton 3100
I was sad that I had no shoes until I met a man with no feet..
Leo Offline
Moderator
Moderator
I can go crawl under mine tomorrow and check. The tank and brackets are original.
Mark, here's a picture of my brackets before i unbolted them from the frame. looks like the front and back are different. brakets to frame
tanks straps with the brackets that bolt to the plywood floor. original straps to floor
new straps connected to brackets new tank straps
tank installed straps not tightened up yet. tank installed straps not tightened yet
tank pictures
will these pictures help ?
Tim
1951 3100 Chevrolet
Thanks Tim! I asked that question back in 2006 when I had the body off of the frame. I'll have to crawl under there to see what I was talking about. Maybe we can help Larry figure out what is going on. I haven't thought about this since I reassembled the vehicle. Now I'm curious again. More to follow!
Leo Offline
Moderator
Moderator
I checked mine and it is tight to the inner part of the frame rail, both brackets.
Is there rubber between the tank and strap? If not maybe that's why there is a gap...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
There typically is, I used rubber sheet cut down. http://www.bunchobikes.com/1952suburban58.jpg The area we are talking about is where the main bracket attaches to the frame.
