1 members (wilbur53),
92
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | this sounds like it would be nice, but how do you set up your clutch and brake pedals. mine right now are mounted to the transmission on one side and e brake on the other. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | If you can keep the bell housing the clutch linage will be the same. A mount for the E brake will have to be made. That might not be too hard. Bolt to the transmission? There are some bolts on the output end of the T 5 that might support what you need. There are some Tech-Tips that cover some of the issues. This is just one of them: http://www.stovebolt.com/techtips/t5tranny.htmOthers will know more.
Steve H
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | this sounds like it would be nice, but how do you set up your clutch and brake pedals. mine right now are mounted to the transmission on one side and e brake on the other. If you can keep the bell housing the clutch linage will be the same. A mount for the E brake will have to be made. That might not be too hard. Bolt to the transmission? There are some bolts on the output end of the T 5 that might support what you need. There are some Tech-Tips that cover some of the issues. This is just one of them: http://www.stovebolt.com/techtips/t5tranny.htmOthers will know more. The link shown above has good info but there are additional ideas that can help a lot. The 14 spline Astro clutch disc is hard to find. So a better alternative is the Jeep Input Shaft Swap which allows you to use the original 10 spline clutch package. The bell housing needs to have the 4 + 11/16" center bore. Otherwise you'll need an adapter ring or go with the expensive adapter plate. See my signature for more T5 info. | | |
