0 members (), 155 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
#1139974 12/18/2015 7:23 AM
this sounds like it would be nice, but how do you set up your clutch and brake pedals. mine right now are mounted to the transmission on one side and e brake on the other.
jetmech6868 #1140215 12/19/2015 8:05 PM
If you can keep the bell housing the clutch linage will be the same. A mount for the E brake will have to be made. That might not be too hard. Bolt to the transmission? There are some bolts on the output end of the T 5 that might support what you need. There are some Tech-Tips that cover some of the issues. This is just one of them:
http://www.stovebolt.com/techtips/t5tranny.htm
Others will know more.
Steve H
jetmech6868 #1140224 12/19/2015 10:13 PM
The link shown above has good info but there are additional ideas that can help a lot.
The 14 spline Astro clutch disc is hard to find. So a better alternative is the Jeep Input Shaft Swap which allows you to use the original 10 spline clutch package.
The bell housing needs to have the 4 + 11/16" center bore. Otherwise you'll need an adapter ring or go with the expensive adapter plate. See my signature for more T5 info.
