| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | I once lost the brakes on a single master cylinder truck and was nearly killed. never aqain. I have a 55 chevy c.o.e. and want to install a dual master cylinder setup. any ideas? | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Koolkar, Check out this thread.. https://www.stovebolt.com/ubbthread...rake_conversion_on_a_46_.html#Post708681Also, If you are just a little north of Indy you should come by and take a ride in my 46 with the dual circuit front disc brakes. It stops well enough for me to put my employee's and even my 7 year old twins in it! | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | I would like to come and visit. did the rear lights and mud flaps tonight. when I get the brakes figured out i'll make the trip from cicero to the south side. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Also, make sure that what you get is a 1.25" bore. I used a 1" bore master cylinder and it just isn't quite enough and allows my pedal to go too close to the floor for complete comfort.
| | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | Randy, did I see in Athread you manufacture a front disc brake kits? | | |
