1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 3 Junior Member | | Junior Member Joined: Feb 2004 Posts: 3 | Is there a proper way to sand down my 50 Chevy Pickup? I was going to use a hand sander, but what grade of paper do I use? And how do I primer? | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Well, if you're going down to bare metal start iwth 60 grit, them 80 grit, then 120, keep getting finer as you go. Do small areas at a time. As you do a spot prime it or it will rust over night! | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I'm assuming by "sanding down" you mean old paint removal. If that is the case, 36 grit on a dual orbital sander will make quick work of that old paint. Use etch primer on the bare metal and then use a 2k high build primer on top of that. The 2K primer will fill in the sand marks left by the coarse grit. Then apply a guide coat on the 2k primer and sand with something like 120 or 220 until the guide coat is gone. I suppose it would be helpful if you give us some kind of idea what your current auto body skills are. If you are starting from scratch, I suggest you visit some autobody websites such as autobodypro.com and autobodystore.com. Those websites have a ton of autobody information. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you are going to strip it bare I suggest using 3M's stripping wheels rather than sandpaper. They don't scratch the metal, they don't load up, and they last a lot longer than sandpaper. I have stripped a couple of vehicles by hand and it is a pain.
