1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I ran one of them on a round track race car, with a home-brewed 4" diameter aluminum pulley to keep from overspeeding it at the end of the straightaway when we were turning 7K+ RPM. It worked great, and kept the battery voltage up enough to get better performance from the HEI ignition system. Most of our competition didn't run a charging system and their electrical system voltage was down around 11.5 volts or so. Jerry
| | | | | Joined: Nov 2015 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 36 | YEP! That what we did also. Sold the racecar and trailer and still have a ton of stuff in boxes. I gave away buckets of stuff like HEI's tachs MSD systems, CAMs, heads... LOL the only time I ever made money racing. LOL
1947.2 Chevy 2-Ton 161". Motor- 1962 235cid
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | "The way to make a small fortune racing is to start out with a BIG fortune!" Karl Kiekhafer learned that when he bankrupted Mercury outboard motors trying to dominate AAA racing with a fleet of Chrysler 300's. (Before Bill France invented NASCAR)! Jerry
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | What is the outside diameter of that alternator? The case appears to be square at the back half. To ask another way, what size hole will that alternator fit in? Carl
| | | | | Joined: Nov 2015 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 36 | It Just happens to be same diameter as the stock 6v genarator. I made a lower mount out of flat stock, nothing special. The Denso had to come out a little further than the stock mount would allow.
