1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Looking for a phone charger for my cigarette lighter Found one that monitors battery voltage also ...pic... ...test...quicktime... 11 dollars on amazon... Ill report back when it fails | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Thanks for posting this contraption. Have utmost faith that it will last forever & not drain the battery one day  The video was great - what are the four fx? I saw temperature (air), bat voltage, and I think time- don't know what the "0008" was. I'm also interested in how bright it may be at night. Sometimes that blue can be annoying if it's too bright. Brad Wrench Fetcher, PhD | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Volts. Reads U Temp. Not accurate, probably pics up residual heat Amps. 000A
I think it reads amps from the two usb ports when the phone is charging
An amber light would be better, but the blue is not blazing
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I like it, even the blue lights, does it come in 6v??????
Kiddin' of course. But it wouldn't hurt to hook my lighter socket up to the voltage booster circuit that powers my tach and Sony. I smoke no more so the 6v lighter has never been used.
Now that I think about it, most of those devices operate on 5v anyway......I just wonder........naw, got enough projects goin' on now. Like to see what would happen if you did plug that into a 6v system, I'm bet it would work. Denny G
Denny G Sandwich, IL
