12 members (Paul_WNC, Wally / Montana, Woodcmiami, Joe H, baldeagle, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, lumbersawyer, 1 invisible), 94 guests, and 2 robots.
Topics128,040
Posts1,055,475
Members48,424
#1137937 12/05/2015 3:57 PM
Hi Y'all On my 52 Chevy 3600 I need a return line from the Fuel Pump. Could you provide Pictures of how you Installed your's. I'm aware of the dangers...
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
What kind of fuel pump?
Standard engine/carburetor/fuel-pump?
Return line from-where and to-where?
https://www.icloud.com/sharedalbum/#B0NGqkRUiGr3Gag
Over on the right rail. I have an intank pump, and tank from tanks inc.
If using in cab tank? Buy a sending unit that has a fuel line on it (slightly later model truck) use that as return.
1952 Chevrolet 3800 pickup
---All pictures---
One like this: As suggested by Grigg.
http://www.classicparts.com/1954-59...t-Style/productinfo/23-525/#.VmPh2vkrK1s
The delivery side is the bottom of the tank, to the pump and the return is to the top of the sender unit. Fits without modification to the tank. Just need to run a good quality line under the cab and up to the tank.
Steve H
Great Thanks And it a 1952 3600 with a 250 from the seventies
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
For use as a return line I'd remove the screen filter on that pickup tube.
---All pictures---
