1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I am just about to assemble a 216. i want to make it 12 volts and use an alternator. This means i need to make sure all the pulleys are the same width. Can I use a 235 harmonic balancer or is there an option to use a different pulley on the alternator?
I am sure this is a simple fix, just one I haven't heard of yet.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wait to see if someone corrects this information.
What width fan belt do you need?
If it is 3/8", you could use any 1953 and later Chevrolet 235/261 6-cylinder 3/8" harmonic balancer.
Earlier 235 balancers would use the same fan belt width as your 216 (about 1/2" to 5/8"?).
Also, I think same car balancer/pulley diameters were smaller/different than on a truck. This would probably not be a problem for your truck/alternator. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | The old balancer is 1/2". So is the water pump. I have another pump with a 3/8 and can make the change easily.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Generator and alternator pulleys are interchangeable, just get a half inch generator pulley---GM, Ford, or Chrysler and use it. Sometimes the pulley needs a spacer and sometimes the alternator shaft doesn't stick through far enough for a lock washer so just clean good and use a dab of red Loctite. Use the alternator fan and don't use Loctite until final assembly. The nut can be heated to remove at a later date.
Evan
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Jim Carter has the 1/2 inch pulleys to fit on you're alt.
Pete | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks everyone,
I will ask an electrical question next in the electrical forum. Need to decide if the change to 12 volts is worth the effort.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Any starter/alternator rebuilding shop should have an alternator pulley in stock to fit your current belt.
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Any starter/alternator rebuilding shop should have an alternator pulley in stock to fit your current belt. That's where I found mine also, for my 55.2 235. Wasn't very expensive either, if I remember correctly.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
