| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | So I am about to swap my 216 for a 250.
The engine I bought has a flexplate (auto trans), so I am starting to gather parts for the clutch since I'll be using my SM420.
While looking up a new flywheel and a clutch kit, I noticed flywheel shims (not starter shims) in various thicknesses. I will be using a new flywheel. Are these shims needed in stock form or are they just if you had the flywheel turned at some point. I admit I have never seen those before.
Larry W.
1953 3800 Dually Flatbed
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I am going to just throw this out there. I have read when you balance a flywheel you do it with a clutch and flywheel together. Maybe that's why the shims are there. I have no experience in this but read it in a few books
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Removed my response
1959 3100 Apache Fleetside
| | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Ok, At first I could not find a description of what they were for, even where they were being sold. I did finally find that description on Summit. Apparently they are intended to correct the thickness lost after surfacing a flywheel. They go between the crank and the flywheel. http://www.summitracing.com/parts/atp-gs3?seid=srese1&gclid=CLj5kfCuwskCFdEXHwod88cEMwQuote from site: "Get proper spacing and engagement with ATP flywheel shims. These steels shims offer you the adjustment that you need after having your flywheel resurfaced. Improper clutch location can be dangerous and uncomfortable. Make it right with ATP flywheels shims." Larry W.
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Looking at the application list unless I am wrong, this shim is for V8's, not 6 cyl.
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Here's a thought- - - -the only time it might be necessary to shim a flywheel after surfacing it would probably be when using the non-adjustable hydraulic throwout bearing that surrounds the transmission snout. Any of the stovebolt clutch linkage with the fork-type throwout bearing actuator and screw-adjustable linkage would make the flywheel surface plane pretty much a moot point. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Along similar lines to Jerry's reply, here's a quote from the Hotrodders forum:
"I grind flywheels daily. If more than .020 is removed from the friction surface on a hydraulic T/O clutch setup. The clutch pedal height will not be correct and won't release as the system was designed. Customer will not be happy. You will get to re-do the job correctly. Flywheel shims are available in several thickness: .020-.035-.050-.085 are a few I have in stock."
I've personally never heard of using one but then again, I've never wrenched on any newer vehicles. Denny Graham Sandwich, Illinois
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Hydraulic clutches have been around since the late 1950's, possibly before that. My 58 Austin Healey 3000 had one, also the 57 MGA I owned. Ditto for the 65 Dodge D-100 pickup with the 318 V8 I used as my first Diesel truck road service vehicle. All of those had a slave cylinder mounted outside the bellhousing, and a regular threaded clutch adjustment. The ones that fit inside the bellhousing aren't adjustable, and they rely on the proper spacing between the front of the transmission bearing retainer and the flywheel friction surface to work properly. The explosion-resistant scattershields the drag racers used before they got smart and started running automatic transmissions were some of the first ones I saw with the internal slave cylinders.
Edit: Spacing the flywheel back could create problems with the starter pinion gear engagement- - - -there's no free lunch! Jerry
| | | | | Joined: Nov 2015 Posts: 13 New Guy | | New Guy Joined: Nov 2015 Posts: 13 | I notice you said the engine was hook up to automatic transmission before. Shims are sometimes use to obtain the right spacing between the torque converter and the flex plate/ flywheel in order to prevent damage to the automatic transmission pump gears. As the torque converter has to be 1/8" out As flex plate / converter mounting pads vary in thickness So shims maybe use whether you have a automatic or standard shift in order to obtain the right clearances between the transmission and engine.
Currently rebuilding a powerglide
You can't see where your going, until you look where you been!
