2 members (Thomaslb, Eddie54),
166
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Is there a decal that goes on the face of the dash mounted 2 speed vacuum switch (48 2 ton)? I know there is a dash decal about speeds (can't seem to find on line right now) but there must be something to tell which side of the switch is high or low. | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Jim -- Check with KC Mongo. As I recall, he recreated those decals and might be able to send you one.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | | | | | | Joined: Nov 2015 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 36 | Jim,
I think this is the one you need for a 1948.
http://www.oldchevytrucks.com/cart/product.asp?prodid=DE239&i=9701|||||
1947.2 Chevy 2-Ton 161". Motor- 1962 235cid
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Thanks That is the dash decal I knew was somewhere, But I'm looking for the one that goes on the face of the shifter (see the upper right of this decal)that tells which side is high and low. | | | | | Joined: Nov 2015 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 36 | AH! I see said the blind man. Hum.... I have'nt seen that one reproduced yet. I don't know if that was a decal. My 47 I think is painted.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Thanks Farm Dawg. Good point, that piece likely was painted. Have to get out the tiny paint brushes. Any chance you could post a pic so I could see what it's supposed to look like? | | | | | Joined: Nov 2015 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 36 |
