8 members (Nick in Manitou, Woogeroo, TexasJim50, baldeagle, Jon G, FAST55, Hanks custodian, mick53),
71
Mod | | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 441 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 441 | I have a 47 AD 3800 with a 216 engine code AFCA685099 which i believe is a 1948 block. The engine came with a distributor no. 1112353. The truck starts and runs on an engine stand.
I have another 216 from a 47 AD 3800 with a distributor no. 1110090 . The engine code for this engine is ECM 25IO43
I believe this engine is older, and comes from a truck whose serial number is 2 ES A 3002 Made in NY. I think this truck is an earlier 47 as it came with the 4 speed with the lever to get you into reverse.
My question: Is the 1112353 a proper distributor in the 48 coded motor ?
I'm putting the motor back together and would like to make sure I have the correct series distributor. The 1112353 utilizes a different point set but i assume the same condenser. I plan to run a 6V system when I get it all back together. Thanks - Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 090 distributor was used with a polarity reversing switch on the starter and uses a special set of points.
