9 members (cmayna, Nick in Manitou, Hanks custodian, RdsLessTaken, homer52, Gdads51, mick53, kurbside bolter, 1 invisible),
79
Mod | | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Where can I buy a coolant temp sending unit for my 58 GMC 270 engine? Have the original gauge but am needing the sending unit.What is part #? Couldn't find at NAPA, Orieleys. Kanker had one but was sure if it would fit.
Thanks for any help
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy dtwbcs, could you please tell us the brand and part number of the sender you found. Have you verified that the sender works correctly with the gauge? | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | When it arrives will update
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Used Ecklar' temperature sending unit.Part# 61-248985-1 which replaces GM p/n 1513321. Istalled perfectly.Just need a female terminal that will fit onto the tip.
