1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#1136509 11/27/2015 1:23 AM
I have recently installed CPP's power steering kit in my 53 1300.
The power steering box is a 1969 and pump is likely 1975.
When I turn right or left I get a loud squeal when the steering wheel is close to maximum turn. There is plenty of fluid in the reservoir and the truck steers with little effort. Iv'e read where this could be a loose belt or a hooped pump but am not sure its either. Any suggestions appreciated.
Could still have air in the line. Try turning the steering wheel lock to lock a bunch of times with the engine running. That will drive out any air.
My vote is the belt...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I will try both and work on the process of elimination.
Is your pump pulley lined up perfectly with the other pulleys? When you reach the maximum left or right, there is a huge load placed on the pump. A misalignment of the pump pulley will cause a squeal even with a tight belt.
Carl
Sir Searchalot
Sir Searchalot
While it is squealing, squirt soap or belt lube on the belt. That will identify or eliminate it. If squeal does not stop, could be air or some bearing. Does take a while for air to escape. Be sure you recheck fluid level!!!!!!
I had similar issues when I first got on the road,the initial problem was caused by slippage which 'glazed' the belt,it was all downhill from there....
I had painted my pulleys during the rebuild including the 'V' grooves which I think initiated the slippage.
After sanding out the pulley grooves to bare metal (which would ordinarily happen over time anyway) and replacing the belt with another new one i've never had the problem since.
More pix on Flickr.
