| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | I have recently installed CPP's power steering kit in my 53 1300. The power steering box is a 1969 and pump is likely 1975. When I turn right or left I get a loud squeal when the steering wheel is close to maximum turn. There is plenty of fluid in the reservoir and the truck steers with little effort. Iv'e read where this could be a loose belt or a hooped pump but am not sure its either. Any suggestions appreciated. | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Could still have air in the line. Try turning the steering wheel lock to lock a bunch of times with the engine running. That will drive out any air. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My vote is the belt... Mike B  | | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | I will try both and work on the process of elimination. | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Is your pump pulley lined up perfectly with the other pulleys? When you reach the maximum left or right, there is a huge load placed on the pump. A misalignment of the pump pulley will cause a squeal even with a tight belt. Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | While it is squealing, squirt soap or belt lube on the belt. That will identify or eliminate it. If squeal does not stop, could be air or some bearing. Does take a while for air to escape. Be sure you recheck fluid level!!!!!!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I had similar issues when I first got on the road,the initial problem was caused by slippage which 'glazed' the belt,it was all downhill from there....
I had painted my pulleys during the rebuild including the 'V' grooves which I think initiated the slippage.
After sanding out the pulley grooves to bare metal (which would ordinarily happen over time anyway) and replacing the belt with another new one i've never had the problem since.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
