8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 37 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 37 | I have a 1940 1/2 ton, SB. I would like to have body removed and set on new chassis. Any suggestions or ideas are welcome. Also adding a 350 crate engine and compatible tranny. Is it better to replace front end or replace complete chassis. I would like a somewhat smooth ride, if that's possible. Thanks | | | | | Joined: Nov 2011 Posts: 12 New Guy | | New Guy Joined: Nov 2011 Posts: 12 | I have a stock frame on my '41 with a mustang 11 front end, power steering and brakes. The rear is a late '60s (3.09 ratio) with parallel springs. The engine is a '63 corvette 327 that is slightly warmed over. It handles nicely but it's still a truck ride. I'm very satisfied with it out on the road.
cometman
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Beebs, check out the HiPo shop for modified trucks, lots of ideas. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I have a 1940 1/2 ton, SB. I would like to have body removed and set on new chassis. Any suggestions or ideas are welcome. Also adding a 350 crate engine and compatible tranny. Is it better to replace front end or replace complete chassis. I would like a somewhat smooth ride, if that's possible. Thanks My '46 (same cab) is on an S-10. I can't say enough good about the ride and handling. And that way it's easy to get suspension and brake parts. | | |
