1 members (Hush), 73 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
Any solution to the wiper washer stuck on and also my two speed factory motor is stuck on high speed. Not sure how these are supposed to operate but I took the top of the pump housing off and the plunger continually pumps.
could it be the switch on the dash?
3B Offline
Hy bigdog58, I would unplug the wires from the switch and see what happens. The motor works by being grounded through the switch, so if everything stops the problem could be the switch, if everything still carries on then the wiring is shorted to ground somewhere, hope that helps.
thanks...I'll try that next
