| | | Forums66 Topics128,087 Posts1,056,119 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | Can anyone point to a answer or thread on this topic? I ve found 4 year old threads. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Short of using the kits sold for the smaller trucks that use a later model GM power steering gear box there has not been a well discussed option. I've used an IH Scout steering box except it is not a simple swap, I also swapped front axle and the steering geometry/linkage is completely different.
A decent option in this sort of situation is browse the junkyards and see what you find that might be adaptable. Let us know what you find.
Grigg | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There are mainly two kinds of steering, fore and aft or side to side movement of the drag link.
Saginaw boxes are pretty much the same. The pitman arm is allowed to be attached only one way, being located by a skip spline on the shaft, however, if one gets a small, 3 cornered file and entertaines oneself while watching a ball game, etc., one can remove the skip spline from the pitman arm, thus allowing any mounting rotation and location. Then it is only a matter of mounting configuration and suitable brackets. Make sure to mount the box securely, using all 4 bolts and rigid brackets. One will have to adjust the mounting location by trial and error, get a helper to help with the heavy box.
The drag link should be level with the ground in the loaded position. The more it is not level,the more bump-steer one will have. If a panhard bar locates the axle, the drag link should be parallel to it.
The box can be ahead or behind the axle, depending on the tire and fender clearance. Some boxes turn opposite way, make sure the one available turns the correct way for your application.
For my '37 GMC application, I used the box that came with the P3500 HD axles I used, since they were wide enough for fore and aft movement of the drag link, just had to shorten the drag link some.
Good luck.
