4 members (Wally / Montana, tclederman, Donf, cmayna), 91 guests, and 2 robots.
Topics128,086
Posts1,056,101
Members48,434
#1135858 11/23/2015 2:36 PM
Can anyone point to a answer or thread on this topic? I ve found 4 year old threads.
29 Ford
http://s1078.photobucket.com/user/c...4-BF50-713F5EDE5632_zps8zoj9vfq.jpg.html
31 Ford
55 panel
95 4 door power stroke
49 chevy 2 ton
47 2 ton grain bed w/ hoist.
Many trucks waiting
Short of using the kits sold for the smaller trucks that use a later model GM power steering gear box there has not been a well discussed option.
I've used an IH Scout steering box except it is not a simple swap, I also swapped front axle and the steering geometry/linkage is completely different.
A decent option in this sort of situation is browse the junkyards and see what you find that might be adaptable. Let us know what you find.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I used a reverse rotation Saginaw box out of a mid 70's dodge 4x4. Took a lot of planning and careful measuring, but it was the only solution in my case to retain the original steering geometry
http://i131.photobucket.com/albums/...13-2828-000002C01B3A58A1_zps45bcf9e3.jpg
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
Crusing in the Passing Lane
There are mainly two kinds of steering, fore and aft or side to side movement of the drag link.
Saginaw boxes are pretty much the same. The pitman arm is allowed to be attached only one way, being located by a skip spline on the shaft, however, if one gets a small, 3 cornered file and entertaines oneself while watching a ball game, etc., one can remove the skip spline from the pitman arm, thus allowing any mounting rotation and location. Then it is only a matter of mounting configuration and suitable brackets. Make sure to mount the box securely, using all 4 bolts and rigid brackets. One will have to adjust the mounting location by trial and error, get a helper to help with the heavy box.
The drag link should be level with the ground in the loaded position. The more it is not level,the more bump-steer one will have. If a panhard bar locates the axle, the drag link should be parallel to it.
The box can be ahead or behind the axle, depending on the tire and fender clearance. Some boxes turn opposite way, make sure the one available turns the correct way for your application.
For my '37 GMC application, I used the box that came with the P3500 HD axles I used, since they were wide enough for fore and aft movement of the drag link, just had to shorten the drag link some.
Good luck.
