7 members (Jon G, GMCJammer51, Otto Skorzeny, Greg_H, TUTS 59, 1955 1 Series, Joe H), 162 guests, and 6 robots.
Topics128,078
Posts1,056,044
Members48,433
#1135773 11/23/2015 1:31 AM
A Cuban friend told me that in Cuba machine shops could bore out a 216 crankshaft so that the rod bearings would be pressure lubed. Each hole had to be bored in the correct place and then plugged. Does anybody know of a US machine shop that can do the same?
Any competent machine shop can do it the question is, At what cost.
Tim White
49 Chevy panel
91 Jeep YJ
Yes, it can be done. One true believer here had that modification done to his crankshaft, but he never really managed to explain why he thought it was better than the dipper and squirt system that kept untold millions of stovebolts lubricated for 30-something years.
1 Offline
Just swap in a later 235 full pressure engine, people give them away for free on this site quite often. I would think that would be a more practical and cost effective solution. Drilling the oil holes in the crank can't be cheap.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
ponder48 #1136048 11/24/2015 12:49 PM
well that isn't necessarily true, very few machine shops can do it, the only place I have found is crower cams. They only charged $150. I even had a few machinists tell me it couldn't be done, and if you look at the 216 comopared to a 235 it doesn't look easy, but it can be done. you can use a 235 crank, but you need custom pistons. That is the expensive part.
Even if a shop existed in Cuba with the capability it is highly unlikely that would be done. Cuban "stovebolts" are really Toyota's, Lada's, Perkins (India), and anything else that could be cobbled together with locally available parts meaning anything other than GM. I thought I would make friends bringing points, plugs, and other wear parts with me....WRONG!
You Tube
