| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I bought one of those $550 repro radios for my '53 3100. It looks great & works ok but the sound gets distorted when I turn it up loud enough to hear when I'm driving on the highway. An audio guy that looked at it said that the speakers were fine but needed a box behind them to concentrate the sound. Has anyone had a similar experience & if so, how did you fix it? Thanks
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would say that either the radio is defective or the speakers are not up to the job. the lack of an enclosure will not cause distortion. I would call the people that sell or make the product and tell them the problem. They talk about 180 watts of power which actually should have a distortion figure associated with that. However, that is a lot of driving power. | | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 |
