1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Unfortunately in England we dont get the choice of parts that you do, the shipping costs are often too much.
There is a company here that can lower (dearch/reverse eyes) my front springs.
As my truck is in many pieces I cant really check but want to know if i get my front springs lowered by 3" am I going to run into problems. Is there room to get them lowered by that amount, will the bump stops be up against the frame??
Many of you im sure have probably done this so may seem a dumb question.
Any help appreciated. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I would not recommend making ANY lowering modifications to the stock front suspension. They can be wonky enough in their stock form. Lowering will alter steering geometry, and may lead to bump steer by changing the drag link orientation. If you are serious about lowering it and have it drivable and safe, you should consider going to an IFS. Carl
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Jonny,
I did my drop by getting the front axle bent. Not sure price to your neck of the woods. I have pictures in link below. FYI, i took a few leaves out also.
Chris | | |
