1 members (Ponchogl),
163
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | I've been trying to fix a hot starting issue with our 6 volt 235.
Usually when hot, they starter would "click" but not turn the engine. Since the battery was relatively new I assumed we were dealing with a starter issue.
We bought our first rebuilt Napa starter (solenoid type). It performed worse than the original starter "clicking" 12 times out of 13 attempts. Since it was new I started trouble shooting the power source. I cleaned both engine and battery ground cables along with the B+ cable. Then I took the battery out and tested it = 100% @ 600 CCA. Then I bench tested the starter which performed normally with no load. Then I used a remote starter switch to rule out ignition switch issues. Still mostly "click".
We returned the first starter and traded it for another rebuilt 6V. The 2nd starter worked great right out of the box and we were thrilled. Excited that the starter was finally reliable, I took the 3600 to work today. The trip in went off without a hitch. I changed the oil at our shop in the afternoon. When pulling it out of the shop I had a few failed starting attempts then it worked. On the way home I stopped for beer and came out to another failed starter. After about 25 attempts a intelligent young fellow came up to the door and asked if I needed a push. Driving this truck I've learned there are ALWAYS folks willing to lend a "push" to get me down the road. When I arrived home I was convinced that my battery hadn't been charging so I checked voltage with the engine running = 6.5-7 Volts. Then I assumed the battery must not have enough capacity to crank the engine. I monitored voltage while cranking, or "clicking". With the starter engaged but not cranking I'm seeing 5 volts. It looks like I have another [censored] starter.
Needless to say I'm thoroughly irritated at this point.
Could anyone suggest a quality starter source or rebuilder?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are you certain that your battery cables are BOTH at least 2 gauge.
It is preferable to use 1 gauge or 0 gauge or 00 guage (the best) cables for both cables. | | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Both ground straps are braided cable style, so I'm not sure what gauge. The battery cable is pretty fat, but I'd have to measure it to be sure. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Could anyone suggest a quality starter source or rebuilder? I can suggest the guy who has been rebuilding my electrical devices for 30+ years, but he's in Pulaski Tennessee. The shipping would be considerable to send him your starter, but I believe the results would be worth the effort. PM me if you'd like to communicate with him. Jerry
| | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | Try to jump the small terminal on the solenoid to the battery terminal. Sounds to me like you are not getting enough current flow through the trigger wire. Also is there any chance you have a 12 volt solenoid on the starter?
1949 3100
| | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | I had very similar issue. Removed old 2 gauge cables, cleaned up connections and replaced both 00 guage. Vroom! Warm start issues solved. | | |
