3 members (60steve, rfs56trk, TexasA&M48Truck), 79 guests, and 0 robots.
Topics128,212
Posts1,057,463
Members48,471
I need to replace the rear hub bearing for my 1946 Chevrolet 3/4 ton rear axle. The bearing numbers are KB-11630-Z inner and the outer are KD 11786-Y. I found two inner bearings but they are flat roller bearings and not rounded barrel roller bearings like the original? What is the part number for flat roller outer bearings?
3B Offline
Hy Old1946truck, the replacement bearing number for the standard tapered roller bearing will be the same as the part number for the New Departure Hyatt barrel bearings KD-11786-Y, the components of those bearings are Bower 388A and 382, hope that helps.
Moderated
Moderated
1 Offline
To old1946truck I myself have a 1946 chevy 3/4 and was wondering if you ever found a ring and pinion set I thought you were looking for a 4.10
