7 members (baldeagle, TUTS 59, niobrarafun, Nick in Manitou, lumbersawyer, SmalltownTRKGuy, 55shaker),
108
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | I need to replace the rear hub bearing for my 1946 Chevrolet 3/4 ton rear axle. The bearing numbers are KB-11630-Z inner and the outer are KD 11786-Y. I found two inner bearings but they are flat roller bearings and not rounded barrel roller bearings like the original? What is the part number for flat roller outer bearings? | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Old1946truck, the replacement bearing number for the standard tapered roller bearing will be the same as the part number for the New Departure Hyatt barrel bearings KD-11786-Y, the components of those bearings are Bower 388A and 382, hope that helps. | | | | | Joined: Feb 2016 Posts: 2 Moderated | | Moderated Joined: Feb 2016 Posts: 2 | To old1946truck I myself have a 1946 chevy 3/4 and was wondering if you ever found a ring and pinion set I thought you were looking for a 4.10 | | |
