1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1134971 11/18/2015 9:29 PM
I am running with 3.73 crown and pinion if I go taller will I get more top speed and how much and what else would I need to do.
Mark
Mark Ratcliffe #1134972 11/18/2015 9:43 PM
Mark,
In short, yes you will get more top speed at the same RPMs but you will notice that the truck will take a little longer getting up to speed.
I especially like gearing so maybe I can help. A 3.73 rear diff will give the truck plenty of power but the engine will really wind up at highway speeds. It really depends on what kind of driving you plan to do. If you want better highway RPMs (lower RPMs) and better fuel mileage, then you should look for an overdrive transmission with a 0.72 OD gear (0.68-0.78 would be the ideal range). With the OD gear you will not lose any performance in the lower gears at slower speeds and you will enjoy the drop in RPMs at higher speeds.
Many folks decide to swap the rear axle 3.73 gear for a 3.08. That also helps but the down side is a loss of performance in EVERY gear. This is not a problem for a V8 with lots of HP. However, it MIGHT be a problem for a tired inline 6.
If you are opposed to changing transmissions, then the only option is to swap for a taller rear diff gear.
Personally, I like my setup. I have an inline 6 and a 3.73 rear diff matched with a 5 speed transmission with the 0.72 OD gear. I cruise the highway with RPMs around 2100. My MPG is good too.
Mark Ratcliffe #1135037 11/19/2015 1:21 PM
WOW and thanks, my only problem is that being based in the UK for me to purchase something like the OD transmission will cost me a fortune where as going to a 3.08 crown and pinion is only £120, ok i have already bought bearings and an overall kit at a cost of £100 so that hasnt been to much of a cost, as for the engine i have sorted that and it runs fine, good compression and all that but i am in the process of adding a 32/36 carb and having the manifold from stovebolt which will allow me to have the twin exhaust, so i hope i dont lose out on performance.
Many thanks
Mark
Mark Ratcliffe #1135039 11/19/2015 1:31 PM
Many thanks
Mark
I think you will enjoy the change to the 3.08, especially if the truck is used as a daily driver. You will notice the highway RPMs will drop about 18%.
Mark Ratcliffe #1135070 11/19/2015 6:12 PM
Just had a look throughout all you projects, you really are a clever fella, i can see you getting board with my questions that i ask as i am just a novice
Regards
Mark
Mark Ratcliffe #1135096 11/19/2015 8:55 PM
Sir Searchalot
Sir Searchalot
Didn't know you had the Autobahn in UK. Over here, in my experience, the 3:73 was always the perfect compromise ratio. We all like our quick starts now and then. Who knows? you may go to a V8 someday.
Mark Ratcliffe #1135097 11/19/2015 9:05 PM
"Didn't know you had the Autobahn in UK."
Motorways in GB - 70 mp/h (112 km/hr)
Mark Ratcliffe #1135111 11/19/2015 10:53 PM
Sir Searchalot
Sir Searchalot
Understood. The comment was in jest indicating "what's the hurry"? (in a 6 cyl) (Autobahn has some areas of unrestricted/suggested speed limits only) I just don't go over 55 in an older truck. I get there soon enough. As indicated, I like a 3:73. That's all. I don't know what speed Ratcliffe is after.
Mark Ratcliffe #1135112 11/19/2015 11:06 PM
No problem, Bartamos,
I only posted it because the Autobahn's has speed limits in only "congested" ("built-up") areas - enforced speed limit. There is no speed limit in many areas - but, you have to have your car under control.
It is incredible cruising Autobahn at 100+ MPH in a little car.
On Interstates here, I often cruise in my truck at 60-65 (with 3.55 R&P).
Mark Ratcliffe #1135113 11/19/2015 11:08 PM
I agree but I was looking for a crushing speed of around 65 to 70 on the motorways here and would like the lower RPM to give better fuel ecomany as I intend to go to the classic in le man's next year and that's close to 1000 miles
Mark Ratcliffe #1135119 11/19/2015 11:34 PM
If your brakes and suspension and tires are good, cruising at 65-70 could be attained by using an over-drive transmission. That "solution" would most likely be your least expensive way to lower RPMs.
What is you engine and size truck? Someone will post helpful info.
Mark Ratcliffe #1135120 11/19/2015 11:35 PM
Sir Searchalot
Sir Searchalot
That does sound like a formula for 3:08 or 3:42. There are importers of American classic trucks and cars in UK. Maybe one of them could help you out with OD. Like stashing one in the lorry bed or car boot when shipping from U.S. smile
Mark Ratcliffe #1135127 11/20/2015 12:14 AM
I have the 230 in an 8 ft fleetside
Mark Ratcliffe #1135147 11/20/2015 2:08 AM
Sir Searchalot
Sir Searchalot
Chevy called the optional rear ratio 3.07 in 1963. That will probably be needed to wind up the 140HP to 70MPH without stressing motor or mileage if most of your usage is highway. The 3.73 was the std ratio. Sounds like you have a set of parts to do the swap. Good luck. Let us know what kind of effect it makes on both ends.
Mark Ratcliffe #1135590 11/22/2015 8:38 AM
My first truck was a 63 C10 with the original 235, granny low 1st gear trans and 3.90 rear end. I swapped in a 3.08 rear end out of early 70's C10 with an automatic trans and it worked great. It was very nice to drive. I lowered the highway RPMs to a reasonable level and didn't sacrifice much performance. I never raced it and was in no hurry to launch off the line so I was perfectly happy with the result. I even towed a small camper trailer with the truck without issue. That was the only time I ever started the truck in 1st gear.
Bottom line: I think you will be very happy with the 3.08 swap.
Larry
Larry_58_Burb #1135608 11/22/2015 2:41 PM
Larry,
Many thanks for your input you have convinced me to go to a 3.08 as i was a little concerned and i was thinking about a 3.42 but you have settled my mind on the 3.08
Regards
Mark
bartamos #1165464 05/15/2016 7:05 PM
Hi I have tried to fit the 3.08 into my rear axle and when I put back the pinion gear seems to big as it causes the planet gear casing to stick out making it impossible to put back slide in my half shafts any ideas, also bought a 3.42 crown and pinion and thats the same can you get a thinner planner case or could I get another axle but I don't want to lose my 6 stud
