| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | The water pump, which I believe is original, on my 1954 Chev 235 Hydra-Matic pickup has a casting number of "GM 2932 A" under the pulley on the ramp of the housing. There are no other numbers on the body. Generally, I see early 1950s 216/235 water pumps with the casting number "839403" on the radiator hose inlet. Can anyone shed some light on my pump number? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The water pump body would be 839403 for probably 1941-through 1955-1st series (small Chevrolet trucks, at least).
What is the size of the pulley groove? 1953 through 1955-1st had a 3/8" groove
Different groove sizes and pulley diameters were used in different years and on car vs trucks.
Maybe someone knows GM 2932 A? | | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | It does have a 3/8" pulley groove | | |
