2 members (ShopRag, DaveV), 97 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#11345 04/08/2002 4:36 AM
Okay, installed 1961 235 in my 1948 Chev 5 window. Used the original 3 speed. I had the radiator recored to 4 row heavy duty. Used 1 1/2 inch and 1 3/4 inch outlets for possible future small block. The radiator is in the stock location. My new short 235 water pump pulley is 1 1/2 inches from the new core. The center of the water pump pulley is 6 inches from the bottom of the core. Not much room for a fan. I did not get the 235 fan with the engine. Is there enough room for the original 235 fan? Will the low position of the fan on the core work okay?
L. Day
#11346 04/08/2002 6:50 AM
If your interested I sell a adaptor to put the original 48 216 pump and fan on to your 235 to put the fan and pump in stock location.
My Blog
