5 members (KEVINSKI, 1955 1 Series, HandyAndy, Ponchogl, carbking), 101 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
Hi everyone,
I really feel like an idiot asking this, but can someone please help me ID the manufacturer of the regular 3 speed transmission? I ultimately need to find a vendor for a rebuild kit, but don't know where to look or what to ask for when I visit vendor sites.
A very bewildered thank you to all in advance.....
transmission gasket set
transmission overhaul manual
u-joint gaskets and seals
u-joint repair kit - if you need it
and/ or, u-joint bolts and/or u-joint bolt clips , if you need them
Other people might have advice about where to find internal parts, if you need them.
The transmission case is the same from 1948 to 54. But they changed several gears in around 1953 so you have to be careful. The the things that usually wear out is the input shaft, the synchronizer and second gear. The 54 synchronizer can be identified by it having 4 lugs inside. I find them by part number on eBay.
