0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | hi all, I have a '53 3100. it is now 12v with all standard bulbs, no LED lights. left and right tail lights, dual filament park lights. I have a signal stat 900 switch in it. I am putting an in-line fuse before the switch and I can't find info on what amp fuse to use, so what size fuse should I protect the blinker system with? also, being that it is now 12v, should I replace the 20 amp fuses for the tail and stop lights with 10 amp fuses? thanks in advance (design)!
| | | | | Joined: Apr 2015 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2015 Posts: 58 | I'm sure someone else will jump in here but I would think 20A would be fine all the way around providing your turn signal wiring is the same gage, or close to the same gage, as the rest of your fused wiring.
The fuse's job is to protect the wiring in the event of a short. A short is infinite amps so your wiring and fuses don't care what the voltage is.... only the amps. If your wiring was designed for 20A in a 6V system it will do 20A in a 12V system as well.
Best regards, Les | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Les is right. Use a 20amp on the turn signals & leave the others as is. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | I read in the tech article, from cletis, about installing blinker kits. He mentions adding a 5 amp fuse to the more simple signal stat 700. He says to fuse the 900 as well but didn't mention an amperage. Perhaps a 5 amp as well? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | As long as the fuse is sized to protect the smallest gauge wire used in the entire circuit you will be fine. How small are the wires on the turn signal unit? 18 Gauge wire = 5 amp 16 Gauge wire = 10 amp 14 Gauge wire = 15 amp 12 Gauge wire = 20 anp 10 gauge wire = 30 amp Hope this helps, Mike B  | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | The wires don't have any identification on them, but they look like either 14 or 16g. Your wire size/amp chart is helpful, and fusing according to wire size is very logical. | | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 | Thanks, Mike B That's exactly the information I was looking for next week  | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Lemmm117, Use your wire strippers to confirm the wire gauge... Mike B  | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | It appears that the wires are 16g. One interesting thing to note is when installing this switch, the directions say CAUTION: power lead must be connected to a line which is hot when ignition is off for hazard warning signal to operate when motor is not running! I'd assume that often times people would hook it up to a power source that is only hot when the ignition is on, and that wouldn't work out too well if your broke down on the side of the road.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The flip side to that is that can accidently leave the truck parked with the blinkers going. | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | ALSO, you might want to wire in a relay for the headlights if one is not already installed.
