2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#113309 01/29/2004 9:45 PM
I
I Offline
Based on Cost, Effectiveness, and Ease of use,
What do you folks use?
Is the actual Bondo I see at Walmart or wherever complete crap?
I have never done body work. I am getting ready to attempt body work and would like to start and end the project with all of the same products if possible.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
"Bondo" brand filler is a retail product and you would NEVER see it in a body shop. It isn't that is so bad, it is "ok" for a cheap filler I guess. The problem is it ISN'T cheap. It costs WAY more than good filler you would buy at the auto paint store, like Evercoat products.
“Basics of bondo types”
"Regular" polyester body filler, and polyester "putty" is basically the same thing. They are both, you guessed it "Polyester" based. Polyester is what fiberglass is made of. The fillers have talc and some other components that give it "body", that is the basic difference between fiberglass resin and polyester body fillers.
The Putties have a finer ground talc than "regular" filler. They cost MUCH more, but are well worth it for skim coats and minor repairs. Being they are polyester they use a hardener and CURE like fiberglass.
The old "spot putties" DO NOT use a hardener and are simply lacquer primer . They are JUNK and should not be used.
Some examples of these products are as follows.
“Reinforced” polyester fillers:
These can be aluminum filled body filler for metal surfaces. I is very hard to sand and not good for the finish work (needs a skim coat of a “reg” filler or polyester putty) but will fill much more per coat reg filler and has more corrosion resistance.
A Fiberglass reinforced filler is similar.
Examples are:
Evercoat’s “Metal-2-Metal”, “Everglass”, “Kitty Hair”, “Tiger Hair”
3M’s 05815 Short stand filler, 05813 Long strand filler.
"Regular" polyester body fillers:
Evercoats RAGE or "Lite weight" and others.
3M's Lightweight body filler #058001
Polyester putties:
Evercoat's "Polyester glazing putty", "Easy sand" and others.
3M's "Flowable finishing putty"#05824 or "Piranha"#05821 .
"Spot putty" (junk, not recommended) Usually found in a toothpaste tube looking container.
Evercoat's "Ever-glaze" #403
3M's "Acryl-green" red or blue #05960,05964,05966
Dupont’s 2286S, PPG’s DFL17
I personally recommend Evercoat products.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Evercoat is good stuff most of the time unless it sits in the store to long
