| | | Forums66 Topics128,012 Posts1,055,317 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I have the powerglide and column shift 1966 c10. I don't have any of the linkage including the kickdown linkage. I could use some help finding that stuff if anyone has an idea where to look. I have been on the internet all day and I am still at zero.
Thanks | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I might think Utah would have some junk yards and used auto parts places that you might consider. Otherwise, the engine guys I have visited with in our area always seem to pass on good leads to that guy that has a bin full of exactly what is needed. What you are looking for is there. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | if you can't locate any locally I think that I still have all of the pieces for it. why don't ypu have any of the linkage. are you installing a powerglide where there was a manual before? there fore you also need the bracket off the side of the frame? ron | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | We do have many wrecking yards in Utah but no automatic's that I have every seen.
I have an automatic frame because at time I was restoring my cab a guy listed a frame on KSL and it was restored already. I bought it for $250 so all I need is all the linkage. I was also able to find an automatic steering column. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you can try Lyle; [email protected] . he is in bonner's ferry in Idaho. he may be able to help you. he is also a member here ron | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Hi padresag
I emailed Lyle but no answer back do you have a phone number or how can I find him here. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | have patience and he will get back to you. people do have lives and may not be accessible to you 24/7 ron | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | HI padresag
I read you first post again and you said that:
"if you can't locate any locally I think that I still have all of the pieces for it."
If you have everything that would be great let me know
Rocky | | |
