1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1132469 11/02/2015 2:47 AM
I bought a 235 that was supposed to be from a 57 car and had been rebuilt. I wanted an engine with hydraulic lifters to cut down on valve noise. The engine does look to have been rebuilt, but it has a code of F55Z which tells me it's from a 55 car and not hydraulic lifters. The rebuilder installed hydraulics, but the seller says he didn't use the engine because he didn't like the valve noise (quite understandable). Is there any way to make hydraulic lifters work properly in a non hydraulic engine?
That's right: Z = 1955 car 235 with standard transmission - mechanical lifters
You'd have to get the block drilled to provide an oil journal for the lifters (so I have heard).
You might want to put mechanical lifters back into the engine?
H Online: Content
Maybe- - - -if the block has the drilled oil passage from front to back through the lifter bores, the solid lifters can be replaced with hydraulics without a problem. If the passage isn't there, find another block.
Is there a difference between the hydraulic lifter camshaft and the solid lifter camshaft?
If so wouldn't he also have to change cams.
H Online: Content
Yes, there is a major difference in the lobe profile. The hydraulic cam has very short "acceleration ramps" that stack all the parts of the valvetrain together before the valve actually starts to lift. A solid cam has a longer area of slow lift that corresponds to the clearance specified by the cam grinder.
Thanks, I was afraid that would be the response.
