5 members (Nick in Manitou, MickeyP, Jay R, MikeStone1953, 1 invisible), 134 guests, and 4 robots.
Topics128,026
Posts1,055,405
Members48,422
#1131922 10/29/2015 7:59 PM
Sir Searchalot
Sir Searchalot
Does the 60-66 or 63-66 original power assist/power steering unit fit 1/2T and 3/4T frames? Are the frames the same up front?
yes they will fit. cross members are interchangeable
here are the differences in frames
Frame dimensions are as follows:
1963-66
½ ton 2WD: 6-1/32 x 2-1/2 x 5/32
¾ ton 2WD: 6-1/8 x 2-17/32 x 3/16
One ton 2WD: 8-1/8 x 2-13/16 x 3/16
½ ton 4WD 115” WB: 8-1/32 x 2-25/32 x 9/64
½ ton 4WD 127” WB: 8-1/8 x 2-13/16 x 3/16
¾ ton 4WD: 8-1/8 x 2-13/16 x 3/16
As you can see, even the ½ ton 4WD long bed uses the same size frame member
as the one ton 2WD.
1960-62 frame ,measurements
½ ton 2WD: 5-15/32 x 2-1/4 x 1/8
¾ ton 2WD: 7-3/16 x 2-3/4 x 3/16
½ and ¾ ton 4WD: 7-13/64 x 2-3/4 x 3/16
ron
Sir Searchalot
Sir Searchalot
