1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#1132378 11/01/2015 6:01 PM
I'm having a heck of a time trying to remove the bolts in the forward end of the rear leaf springs on my '38. The hangers at the back end were simple enough, but the front bolts don't want to cooperate. I haven't yet resorted to brute force out of fear that I'll cause a bigger problem.
If I'm reading the shop manual right, the forward end is simply a plain bushing with a bolt through it. If so, brute force may be the right method. Can anyone give some advice? Thanks.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Can you get a pneumatic impact wrench on it? If not, you can apply heat from a propane or acetylene torch and use a wrench or breaker bar with a pipe on the end. There is nothing to hurt there since you don't need to get anything really hot to free it up.
Carl
Soak the whole assembly with something like KROIL for a few days, then do the breaker bar and cheater pipe thing.
www.kanolabs.com
Last resort, use a sawzall between the spring eye and the hanger on both sides, and replace the bolts with new ones on reassembly.
Thanks guys. I do have an impact wrench so I'll let 'er rip. Will also soak for a while first, and if all else fails I'll cut it out.
Thanks again.
1938 Chevy 1/2-ton
For anyone reading this after the fact who may not have air tools, you could also find a local community college or trade school. Ask someone there to whip out their impact and give it a turn. One of us would be more than glad to lend you a hand. Towing the truck there would, of course, be up to you smile
