0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Rechroming being out of the question at this time due to budgetary constraints I have cleane up the hood emblem and both fender emblems for my 59 Apache. Am about ready to begin masking in order to repaint the black and red backround areas of these pieces and am wondering what type of paint will be suitable for holding to these chrome pieces. Most of the original paint is still intact and holding well and this will be a temporary job until the budget allows rechroming (no more than a year likely). Would just rattle can enamel suffice or should I consider an epoxy or something else. By the way, has anyone had these pieces rechromed lately and at what cost.
Bruce
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | WB - I had the same situation with my emblem. I opted to go the paint route until such time that I can afford to rechrome or replace. I sanded down the rust and bubbled chrome, then used a rattle can primer. I used Rustoleum primer for heavily rusted metal. I have had good luck with it. It seals nicely and takes rattle can enamel very well. That was 4 years ago and it stil looks great.
Deaner 1950 Chevy 3600 Stake Bed
I don't know where I'm going, but there's no sense being late!
| | | | | Joined: May 2001 Posts: 13 Junior Member | | Junior Member Joined: May 2001 Posts: 13 | I WORKED PART TIME AT A CHROME SHOP LAST SUMMER, WHAT TYPE METAL IS IT, STEEL OR POT METAL?? POT METAL DOES NOT CHROME WELL AS THE ACIDS USED TO PREP THE METAL FOR THE FINAL PLATING HAS A TENDENCY TO CAUSE BUBBLING IN THE FINAL FINISH, IF IT'S STEEL IT SHOULDN'T BE A PROBLEM...ALSO THE SIZE,CONDITION OF THE METAL PIECE WILL DETERMINE THE AMOUNT OF WORK TO BE DONE. WILL IT BE NICKLE-CHROME PLATTED(CALLED DOUBLE PLATTING) OR TRIPLE PLATED, SAME PROCESS AS DOUBLE PLATING BUT INCLUDES A LAYER OF COPPER BEFORE THE FINAL CHROME PLATE IS APPLIED) ALL THIS WILL DETERMINE THE PRICE...HOPE THIS HELPS IN YOUR DECISION AS FAR AS AFFORDABILITY....ALOHA | | | | | Joined: Feb 2000 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 57 | Hey Ranger-53, I was in Honolulu 3 weeks ago and only saw ONE "stovebolt" AD Chevy truck driving down the road. It was going the opposite direction so I did not get a real good look at it but it was blue. Was that you?? It looked good, not much old Iron on the Island driving around! Mahalo [img] http://www.thevirtualgarage.com/bboard/ubb/biggrin.gif[/img]
Kelly 1951 Chevy 3100 1967 RS/SS Camaro
| | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | wbkinsey, I painted my emblems using an airbrush and model train paint (modelflex). Worked great. The paint is cheap, comes in hundreds of colors and can be bought in small quatities. An airbursh can be had for as little as $15. If you want to see how I did it and the results, check out http://pattson.web1000.com/maych/mh_pro_9.htm 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
| | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Great web site, JohnnyP!
Thanx for taking the time to record Maych's restoration. I found lots of good ideas to use in my own rebuilding efforts. | | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | LAROKE, thanks for the compliment. I especially appreciate it coming from you. I got the inspiration for my site from reading about your adventures with Billybob.
Just read #17. Funny, but I too just purchased and got approval to put a 1972 Nebraska plate on Maych. The best part is I don't ever have to renew the registration - it's good for life, so no "little stickers" to muck up the look.
Looking forward to #18. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
