| | | Forums66 Topics128,094 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Len Stuart, the proprietor at www.autobodystore.com posted a message on the bulletin board, with photos yesterday, showing the results of a 16 month test of the 2 products on a salt water fishing boat. It was a set of circumstances for acceleration of failure. I do the same thing in the elements on the Oregon coast. It's quite an incubator. Like the salt spray test cabinet with everything else thrown in. Anyway,thought you all would like to see it as there seems to be a fair amount of discussion on the topic of rust control. It's not everyday you can see real world test results like this. I think, as much as anything, Len was trying to prove to himself that the product he had begun to put his credentials behind (ZR) did, in fact, do the job. This result is not offered to down grade the performnce of POR 15 but merely to show the viability of ZR. It's hard to show direction with only one stake in the ground..... Bruce Palmer [email protected] Salem Or | | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | | | | | | Joined: Nov 2000 Posts: 17 Member | | Member Joined: Nov 2000 Posts: 17 | Here 'tis: [URL=http://www.autobodystore.com/cgi-bin/config.pl?read=63492][/URL] WK Irish | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Neat site! Is that a 250 Chev or a **** 300 in that boat? Or some kind of diesel? ON the paint...thought you didn't need a primer when using the top coat and maybe it is better not to. thought the paint needed to turn the rust to some other compound and stick to it to work. No?
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Hey guys, how come you can advertise Zero Rust and no one is supposed to run ads in the forums? | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Tony Good call -- but the folks at Zero Rust had worked with us a while back on a few Tech Tips on Rust. We previously had some good intel on the POR 15 stuff, too. So, this looks like a good thing to show an independent study of the two. Most 'Bolters were familiar with POR 15 ... wanted to give the ZR folks a chance to "show their stuff." As we all know, Rust is the cancer to our old Stovebolts ... so this is good info. Bill Irish / Zero Rust has sponsored previous newsletters (remember when we use to do them and email them out) and also donated a good stash of ZR for the It Ran contest. So ... is otay! Thanks, Peg
~ One of many.
| | | | | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 |
57 3100 235 3 spd
| | | | | Joined: Nov 2000 Posts: 17 Member | | Member Joined: Nov 2000 Posts: 17 | Just to clarify a couple points, Len's test included use of Rass-O-Nil, a rust converter that he strongly advocates/uses. Neither POR nor ZR are converters, that is, neither changes the structure of the rusty metal or, for that matter, the white metal blasted surface they might be applied to. In ZR's case, ZR IS the primer AND the topcoat (unless you top it with something else for esthetic reasons) and this can be done without jumping through another process/product. In our experience, there is no need to use the Rass prior to coating with ZR, in fact and again based on our observations, 9 times out of ten, it tends to interfere with the job ZR is designed to and actually does, ALL BY ITSELF. There are others who swear by Rass and we'd be the last to pour cold water on their experience and advocacy. Forgive me, but "it's whatever floats your boat" -ouch - no pun intended. HTH WK Irish | | |
