| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Hey everyone, I've just completed installing new engine parts on "Lucille". New fuel pump with built in gas filter, new SS fuel line to carburetor, new SS vacuum line from dizzy to carburetor and newly restored Carter W-1 carburetor.
I have a startup question. Since the carburetor hasn't seen any fuel yet, what would be the proper steps in getting it all fired up? I now have a properly hooked up choke and throttle connections.
All input will be greatly appreciated!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The easiest way is pour a little gas in the carb throat to "prime" it. Start it & keep pumping the gas pedal till it takes off on its own. Usually one time will do it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Thank you George!
I was thinking that, but was concerned that air bubbles would get trapped somewhere in the system and create starting problems. I'm ready to get Lucille running again after making decisions to install period correct components. There was a Carter YF carburetor on her and I learned that the Carter W-1 was the historically correct one. I'm pleased with the looks of the right components and will try to fire her up tomorrow.
One thing is for sure, Lucille is a work in progress! AND she's a pretty lady!!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | If this start up is on an engine that is not a brand new rebuild, just close the choke, turn the ignition on, and stomp on the floor starter. Your new pump should be able to fill the carburetor bowl very quickly and it should start right up. Carl
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Another opinion:
Before starting, take a "squeeze bottle" (empty mustard or ketchup bottle), wash well, and fill with gasoline. Use the squeeze spout to fill the carburetor through the bowl vent.
Why?
(1) Easier on the starting motor. (2) May prevent future carburetor issues. Tests have shown that a mechanical fuel pump diaphragm under no load will flex approximately 0.030 more than under load. If the fuel pump has been on for some time, there may be "varnish" build-up on the diaphragm that will flake off due to the additional flex, and flow forward to the carburetor.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | OK folks, it's Lucille again!
Had a wonderful day today getting "Lucille" running again after installing her new historically correct components as I mentioned in my first post.
I purchased this re-manufactured Carter W-1 carburetor from some guys out in CA. Didn't exactly know what to expect once installed, however, today, once I cranked "Lucille" up the newly restored carb functioned beautifully! Just a little gas down the throat like Wrenchbender George told me and wham....Lucille was alive!!
Ran her 32 miles today on the good roads of Murphy, NC. The new carb and vacuum lines installed definitely helped her performance. The only thing I experienced that was negative was what I perceived as a hesitation on the acceleration pedal. Something is sticking down there and it may be something as simple as lubricating the linkage.
Anyway, just wanted to post an update with my experiment with an old Stovebolt.
Keep Stovebolting on!!
